| | | Forums66 Topics128,022 Posts1,055,361 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,746 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,746 | Yep-- - -you lost the spacer. It's a ring about 3/16" thick that fits between the fan and the bearing. I use a 1/2" drive impact wrench to tighten the pulley nut- - - -it needs to be TIGHT! Wrap a belt around the pulley sheave to hang onto while you hammer the nut down with the impact.
Edit: Alternators don't have a key- - - -the friction fit does all the driving. Jerry
