1 members (Hanks custodian),
153
1
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,127 Posts1,056,679 Members48,452 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,837 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,837 | Did you get into the centrifugal timing advance system in the distributor below the breaker plate? Quite often, there's a spring missing or broken, and/or the whole setup is rusted solid so there's incorrect or nonexistent advance at certain engine speeds. "Out of sight- - -out of mind" happens pretty often, and centrifugal advance problems get ignored. The correct advance curve is essential to good performance, especially during part throttle operation. Jerry
Entire Thread
Sputtering,and coughing at 1300 RPM's,
| Chilidogg | 01/05/2017 3:00 AM |
Re: Sputtering,and coughing at 1300 RPM's,
| Hotrod Lincoln | 01/05/2017 4:47 AM |
| Chilidogg | 01/05/2017 5:31 PM |
| baldeagle | 01/05/2017 8:54 PM |
| mechanic58 | 01/05/2017 7:33 PM |
| Hotrod Lincoln | 01/05/2017 9:34 PM |
| carbking | 01/05/2017 9:55 PM |
| Hotrod Lincoln | 01/05/2017 10:49 PM |
| carbking | 01/05/2017 10:56 PM |
| Wrenchbender Ret. | 01/05/2017 11:07 PM |
| Chilidogg | 01/06/2017 5:28 PM |
| beltfed | 01/07/2017 11:26 PM | |
