0 members (),
116
0
Mod | | | Forums66 Topics128,127 Posts1,056,679 Members48,452 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2016 Posts: 11 New Guy | | New Guy Joined: Nov 2016 Posts: 11 | Hi All,
My 53' 3600 with a 235 became roadworthy this week after lots of work. ( woo hoo! How fun is that?)
When driving it performs well except at around 1200 to say maybe 1400 rpm where it acts like its suddenly running on about 4 cylinders.
I put an electronic ignition in it, so no points or condenser to worry about. The distributer does move when I rev it ( It didn't just last week) Fuel filter ls new and clean.
So when driving all is peachy until I get to about 1300 rmps. Under 1200 or so it purrs / after about 1400 it really has some pep. ( surprisingly so)
I'm wondering if I should start with the vacuum advance? As always..thanks in advance for the help! | | | | | Joined: Feb 2004 Posts: 29,837 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,837 | I put an electronic ignition in it Troubleshoot it by reinstalling the points, then act accordingly. Jerry
| | | | | Joined: Nov 2016 Posts: 11 New Guy | | New Guy Joined: Nov 2016 Posts: 11 | Thanks for taking the time to respond. Re-installing the old ignition is doable. However The issue was the same ( a little worse in fact) before I installed the electronic ignition. Not being the sharpest tool in the shed I put in the new ignition system in hopes of remedying the issue. | | | | | Joined: Oct 2013 Posts: 331 Shop Shark | | Shop Shark Joined: Oct 2013 Posts: 331 |
1950 4100 - unrestored and driven weekly for almost no reason at all.
| | | | | Joined: Mar 2000 Posts: 1,182 Red dot, center of chest ... | | Red dot, center of chest ... Joined: Mar 2000 Posts: 1,182 | Thanks for taking the time to respond. Re-installing the old ignition is doable. However The issue was the same ( a little worse in fact) before I installed the electronic ignition. Not being the sharpest tool in the shed I put in the new ignition system in hopes of remedying the issue. Logically then, the problem isn't the distributor or anything related to the distributor (like the vacuum advance.) There must be another cause. I would look at the fuel/air system. With the engine idling, spray carb cleaner on every vacuum hose. If the engine races, replace that hose. If you don't find a vacuum leak, look at the carb. Carbs have four circuits; idle, main, accelerator and power enrichment. From your description, the idle and power circuits seem to be fine, but there's a possibility that the main metering jets or the acceleration system might be the problem. | | | | | Joined: Feb 2004 Posts: 29,837 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,837 | Did you get into the centrifugal timing advance system in the distributor below the breaker plate? Quite often, there's a spring missing or broken, and/or the whole setup is rusted solid so there's incorrect or nonexistent advance at certain engine speeds. "Out of sight- - -out of mind" happens pretty often, and centrifugal advance problems get ignored. The correct advance curve is essential to good performance, especially during part throttle operation. Jerry
| | | | | Joined: Nov 2002 Posts: 2,767 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,767 | Like Jerry, my first suggestion would have been the electronic ignition. Since the same symptom occured with points: From what you have posted, by GUESS would still be distributor. Possibly a "catch" in the rotation of the plates at a certain spot, and then when it rotates past that spot, it functions. Or, as Jerry stated, possibly a missing or broken spring. I would not guess the carburetor, for the following reasons: "Under 1200 it purrs" "above 1400 it really has some pep" The idle circuit should take you to maybe 800, the idle transfer to a little more than a 1000, and then you are on the main circuit. Cannot think of any way the main circuit would be good from 1000 ~ 1200, bad from 1200 ~ 1400, and then good again from 1400 up. Carburetors have no personalities (well, maybe Holleys  ). But ignition systems do have personalities. I would suggest a really good look at the distributor. Jon. Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | | | | Joined: Feb 2004 Posts: 29,837 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,837 | Carburetors have no personalities Surely you haven't forgotten the rotten personality traits of a Rochester B, have you? Fortunately, an attitude adjustment with a 3-lb. hammer is usually all it takes to solve the problem! Jerry
| | | | | Joined: Nov 2002 Posts: 2,767 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,767 | Jerry - the Rochester B has no personality, it just doesn't work 100 percent of the time  By personality, I mean works well sometimes, other times gives problems. Generally speaking, carburetors will do the same thing under the same conditions, thus no personality. Jon. Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Try running it with the vacuum advance disconnected. Sometimes too much advance at part throttle will cause a rough running condition. If that is the cause you will need to tailor the advance mechanisms to limit the amount of advance. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Nov 2016 Posts: 11 New Guy | | New Guy Joined: Nov 2016 Posts: 11 | Thanks everyone! I'll tackle the project this weekend armed with these great suggestions. You guys and this forum are one hell of a fine resource! | | | | | Joined: May 2005 Posts: 1,624 Shop Shark | | Shop Shark Joined: May 2005 Posts: 1,624 | Please be sure to get back to us on what cures your problem.
