Evercoat Company [the fiberglass people] used to make an epoxe based spray product called "Fiberfill", that used the MEKP [methyl ethyl Ketone peroxide] as a catalyst hardener just as the fiberglass resin does. This stuff is messy, hard to spray, clogs a gun with less than a 17 tip, and even harder to clean up, not to mention the fumes are deadly....but it works fantastic on a freshly sand-blasted pitted surface. Oh, and you better block it with 180 within 24 hrs or you will think you are blocking concrete. As a matter of fact, I will be looking for a gallon soon for a '41 Plymouth body....lamarB
70 C30 Wrecker
