Winter is Coming
Yes slick sand will easily fill pits small dents etc.Problem,a little hard to sand,board it with 180 grit then high build prime,as far as bondo cracking,I don't think so on that application,too thin.
Bent Happy Haulin! TWO 1963 GMC\'s -- A shortbox and a NAPCO!
