| | | Forums66 Topics128,140 Posts1,056,467 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2000 Posts: 2,195 Insomniac | | Insomniac Joined: Jul 2000 Posts: 2,195 | I *think* I read somewhere that interruption is best done by breaking the ground side of the circuit. So wouldn't a simple 2-pole switch do the trick? And can I assume that a switch like that would create the break with the button depressed (door closed)? That's correct; but you only need a single pole switch. Run a wire to the lights from the courtesy lamp fuse. Run wires to each door and the headlight switch. Opening a door or turning the headlight switch grounds the circuit and the lights come on.
Gord 🇨🇦 ---- 1954 1/2 ton 235 4 speed | | |
