You can get high temp spray paint at a car parts store. You need to use the kind that is rated at 1500 degrees. I used it on my exhaust pipes and so far it has held up well. If you dont mind paying a little more, ceramic coating works good, it holds up on headers better than about anything I've seen so far.
