2 members (Patharr, 1 invisible),
45
3
Mod | | | Forums66 Topics128,090 Posts1,056,027 Members48,432 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2001 Posts: 1,094 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,094 | If you put the disc in backwards the disk will hit the bolts on the flywheel. Just put it up to the flywheel and you should be able to tell if it is hitting, if so just turn it around.
Tommy 59 apache 1/2t 261 short stepside | | |
