Sounds like you need a different carb repair man. Kits a pretty cheap, and the carburetor is a really simple design. I would go ahead and clean it just so I knew it wasn't the problem. Once you have the fuel system cleaned, then move to the electrical side, timing, points, coil, etc..........
Joe
