0 members (),
133
2
Mod | | | Forums66 Topics128,157 Posts1,056,876 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2005 Posts: 2,101 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,101 | On that transmission the tailshaft will not come off without disassembling the transmission. Once you have the two sections separated you can get to the snap ring if needed. You can replace the rear seal with the housing in place. Fred
1956 3100 Pickup/Red/350/3sp OD/PS/Disc Brakes 1957 Bel Air Sport Coupe/Red/355/TH350/PS/Disc Brakes 2017 Silverado LT Single Cab SB/Black/5.3/6 Speed Trans 1947 Willys CJ2A w/F-Head engine
