Bruce it is easy to make all the parts for the spare tire hold except for the top clamp ( somebody is reproducing the clamp which I believe is the same as 32 & 33 car, There is a large steel frame bracket under the fender that would be hard to duplicate, its held to the frame with 4 bolts. The top nut can be made from hex stock on any small lathe.
