3 members (KEVINSKI, WarEagle1, 1 invisible),
113
2
Mod | | | Forums66 Topics128,265 Posts1,058,366 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2006 Posts: 1,154 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,154 | Thought I'd post what is going on with my SM420 transmission install. The tranny bolted up to the bell housing on my 1956/57 235. The cross member has not (so far) gotten in the way. The dive shaft is kaput I need a new shaft built with a slip yoke no surprise there. The speedo looks like it will plug right in. The exhaust pipe will need to be kicked over as the SM 420 is a bit wider than he old three speed. Novak built a beautiful SM420 it's a latter model there is a back up switch on the top.They used SS bolts on the case and machined a beautiful plate to cover the PTO which I didn't need. So far so good but I'll let you know how the swap goes. For those of you who might want to do this swap. Thanks, Steve | | |
