2 members (50Chevy3100, 41 chev), 143 guests, and 2 robots.
Topics128,265
Posts1,058,365
Members48,485
#1175596 07/27/2016 3:09 AM
Thought I'd post what is going on with my SM420 transmission install. The tranny bolted up to the bell housing on my 1956/57 235. The cross member has not (so far) gotten in the way. The dive shaft is kaput I need a new shaft built with a slip yoke no surprise there. The speedo looks like it will plug right in. The exhaust pipe will need to be kicked over as the SM 420 is a bit wider than he old three speed. Novak built a beautiful SM420 it's a latter model there is a back up switch on the top.They used SS bolts on the case and machined a beautiful plate to cover the PTO which I didn't need. So far so good but I'll let you know how the swap goes. For those of you who might want to do this swap.
Thanks, Steve
thumbs_up
Bill Burmeister
