1 members (1 invisible),
69
3
Mod | | | Forums66 Topics128,081 Posts1,056,319 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,825 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,825 | Are you using an original equipment type oil filter, or an adapter for a spin-on filter? If you're using a spin-on, you'll need to put a 1/16" diameter restrictor orfice in the return line. Otherwise, virtually all the oil will get routed through the filter and back into the oil pan, and very little will get to the engine. that's a guaranteed oil starvation situation as soon as you get on the road with any load on the engine.
It's simpler, and a lot smarter to use the original style canister filter. Jerry
Entire Thread
'54 Chevy PU, Remote oil filter hookup, need help
| jbaker | 07/15/2016 7:07 PM |
Re: '54 Chevy PU, Remote oil filter hookup, need help
| Grigg | 07/15/2016 8:06 PM |
| jbaker | 07/16/2016 10:43 PM |
| Hotrod Lincoln | 07/15/2016 9:47 PM |
| jbaker | 07/16/2016 10:45 PM |
| MikeE | 07/15/2016 10:42 PM |
| tclederman | 07/16/2016 12:43 AM |
| jbaker | 07/16/2016 10:46 PM | |
