I don't think wide base tires are made in anything but 22.5. Instead of messing with adapters, why not put in a modern axle with hub piloted hubs. Zero offset 14x22.5 wheels would give you about the right width or you can go with 2" offset. I use both. And there is a wide variety of ratios available.
