| | | Forums66 Topics128,075 Posts1,055,918 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2006 Posts: 423 'Bolter | | 'Bolter Joined: May 2006 Posts: 423 | I am back in my own garage now trying to get my relatively fresh 235 to run as well as the cracked 216 it replaced. Today I changed the condenser and checked the points, after looking over the good old Rochester B yet again. Afterwards the 235 still runs as poorly as ever. I have described before that one of the troubling things this motor does is that if I get it running well without the aircleaner in place, the RPMs increase when I install the (brand new from Jim Carter) air cleaner. If on the other hand I have it idling well with everything in place and then remove the air cleaner the engine just about dies. So I checked today (with the air cleaner removed) for vacuum leaks by aiming lp gas around the carb, no response. Perhaps I am a little too careful with the amount of lp gas, but still I was expecting to find some enormous vacuum leak and the lp oughta work. I am really frustrated with this new engine. The compression is fine, it doesn't leak so much, I need a visit from one of you extreme posters. We got a spare bed... Karl
It may not be the easy way, but it is the Cowboy Way - Ranger Doug Beware of the stories you read or tell; subtly, at night, beneath the waters of consciousness, they are altering your world. - Ben Okri 1953 Chevy 3100 1960 Volvo PV 544 1941 Chevrolet Special Deluxe | | |
