| Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,870 | It sounds like your master cylinder has too small a bore diameter. You need to move enough fluid to get the pads and shoes tight against the drums and rotors. Try going to a M/C about 1/16" or 1/8" larger diameter and see if you get a shorter pedal stroke. Jerry
