1 members (5 Window 9434),
68
2
Mod | | | Forums66 Topics128,030 Posts1,055,428 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2005 Posts: 1,624 Shop Shark | | Shop Shark Joined: May 2005 Posts: 1,624 | If you fabricate then just find a tank that fits. Remove by cutting and weld patches to anything in the wrong place such as filler pipes or return port for fuel injecting. Cut your holes and weld in your filler pipe and sender port and your done. A new tank will not have fuel vapors so it's a snap.
