7 members (Jay R, Joe H, Jon G, Phak1, Oswald, dt235sd, Gdads51),
103
Mod | | | Forums66 Topics128,268 Posts1,058,391 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2010 Posts: 10,335 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,335 | Cosmo, While I have also read that dielectric grease does not conduct electricity, in my experience, it does not prevent metal-to-metal contact in switches or at terminals, and in fact prevents oxidation and corrosion. I would hold off on gutting the switch at this point. Most dim lights are due to the failure of electricity to go through 60 year old rusty frames, bed sides, and multiple layers of paint. I would suggest that you start by going to the trouble of attaching a long jumper wire from the negative terminal of the battery and the ground of the LED lights. Carl
