| | | Forums66 Topics128,030 Posts1,055,424 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2014 Posts: 385 Shop Shark | | Shop Shark Joined: Sep 2014 Posts: 385 | Im having some slight shifting issues with my t5. When going from 1st to second or second to third i cant shift fast and right into gear. When i just pass the neutral center point and going into second the shifter will move about half the way then tighten up like im hitting interference then it will get easy again and slid the rest of the way into gear and the same thing when going into third. When the truck is at idle at the lights it slides right into gear with no effort. When trying to get aggressive with it shifting into second will always grind. Think my clutch is dragging somehow? pedal travel is not maxed out. It has to be about 75% out to even engage. | | |
