| | | Forums66 Topics128,042 Posts1,055,516 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2008 Posts: 899 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 899 | Since you removed the starter have you connected the positive battery wire to the wire that goes to the ignition? This connection is normally made using the stud on the switch located on the. top of the starter. http://chevy.oldcarmanualproject.com/shop/1948_51truck/51ctsm1203.htm
Ed
