| | | Forums66 Topics128,042 Posts1,055,518 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2014 Posts: 307 'Bolter | | 'Bolter Joined: Aug 2014 Posts: 307 | Recently pulled starter to have rebuilt. Meantime, today installed new electrical windshield wiper motor. Connected the battery and no power.. no lights, horn etc.. checked battery and it is good.. don't see any disconnected wires anywhere. Any ideas? Thanks,Scott | | | | | Joined: Apr 2008 Posts: 899 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 899 | Since you removed the starter have you connected the positive battery wire to the wire that goes to the ignition? This connection is normally made using the stud on the switch located on the. top of the starter. http://chevy.oldcarmanualproject.com/shop/1948_51truck/51ctsm1203.htm
Ed
| | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | Ed is on to something Scott, the starter is the focus of the positive side of the battery. Removing the Starter breaks the positive line. Battery to Starter, Starter to Ammeter - to everything else. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Be sure to disconnect the - lead from the battery before reinstalling the starter. I'm wondering how you got the starter out without arcing. | | |
