| | | Forums66 Topics128,274 Posts1,058,425 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2006 Posts: 1,154 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,154 | That's about right the brake pedal is higher than the clutch just like you described ..why....they wanted to take three inches off but you cut two with no ill effect. The lad has tremendous push strength in his leg his birth defect is the knee and having to lift it at such a weird and high angle it's tuff it's just not lift but it's moving your leg at an angle and lifting from the gas pedal. Perhaps we could start at two inches see what happens. Your fix sounds just right line up clutch and brake pedal for smooth movement. We all need help sometime.... | | |
