When a patch panel is applied and you are butt welding, I know you are supposed to weld small areas at a time spacing them every inch or so. Once you have it all welded,still having the gaps,
do you completely weld up every gap till no holes remain or is it ok to leave some tiny gaps and fill in later when you do the body filler work.
