Assuming 12 volts, Neg ground.
Wire from the dist. to - pole on coil.
Wire from + pole on coil to resistor.
Wire from other side of resistor to toggle switch
wire from toggle switch to + battery.
Wire from starter solenoid to pushbutton switch.
Wire from pushbutton switch to + battery.
keep the switches in hand for when things go wrong.
Good luck
