| | | Forums66 Topics128,083 Posts1,055,967 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2007 Posts: 1,038 'Bolter | | 'Bolter Joined: Apr 2007 Posts: 1,038 | So you are saying that the switch is connected to the motor properly, moves the metal tang on the motor body and it still doesn't shut off? If so, you will have to remove the motor and have it gone over. To remove the motor you may need a clutch head screwdriver to remove the mounting screws as seen in this link. The transmission arms are held by a spring clip. The hard part is working around the instrument clusters/wires that obscure your vision and access. http://s1116.photobucket.com/user/1...inkw_zpsn2v3yjrq.jpg.html?sort=3&o=0If the motor needs rebuild and you don't want to mess with it yourself I recommend wiperman.com Kent | | |
