All true, but the seal in the caliper does most of it. They are square cut on a slight angle, the fluid pushes the piston and seal, when released, the seal pulls back into shape bringing the piston with it. I have been running disk/drum set up since 1999 with no hold back valves, didn't know I needed them. Pedal is stiff each time i need it and master cylinder is the original location.
