O ya!If this is your first attempt at body work this is not realy the best to use.It sands real hard compared to bondo.If you have holes or rust that you are going to fill it will work good.But if you are just doing dents use bondo.The trick to the tiger hair is not to set it off to fast and sand it just after it goes off.dont let it harden all the way.use 36 or 40 grit to cut it folled up by 80 grit.
48GMC 5window,350,700R4,p/w,p/b,and a couple of homemade parts!
41 Sedan Delivery next up to be reborn!!
"Nothing is Junk,just unfinished projects" Desert rat with a spray gun!
