My '59 one ton has a 235 with the stock 4 point mounting system. I have located a 1960 261 which does not have provisions for attaching motor mounts to the front corners of the engine. Instead, it uses a single mount up front similar to early sixes.
Does anyone have suggestions for adding motor mounts like the ones on my 1959 to the front corners of the 1960 261 block?
Oldbolter 1959 Apache 3800 dually flat bed/dump with 261 1956 3800 dually flat bed/dump with 235 1957 3600 flat bed, 350 engine, 700R4, PS, disc brakes, 14 bolt rear with 4.11 gears
