7 members (Woodcmiami, cmayna, Hotrod Lincoln, Gdads51, mick53, MickeyP, 1 invisible),
34
10
Mod | | | Forums66 Topics128,012 Posts1,055,312 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2009 Posts: 152 'Bolter | | 'Bolter Joined: Aug 2009 Posts: 152 | My '59 one ton has a 235 with the stock 4 point mounting system. I have located a 1960 261 which does not have provisions for attaching motor mounts to the front corners of the engine. Instead, it uses a single mount up front similar to early sixes.
Does anyone have suggestions for adding motor mounts like the ones on my 1959 to the front corners of the 1960 261 block?
Oldbolter 1959 Apache 3800 dually flat bed/dump with 261 1956 3800 dually flat bed/dump with 235 1957 3600 flat bed, 350 engine, 700R4, PS, disc brakes, 14 bolt rear with 4.11 gears
| | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | 4 mounts can lead to broken mounts, frame, I know it came that way, however, I would use the 3 triangulated mount system, especially in a truck.
Ed
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | I think you will need to make a mount from the crossmember to the timing plate like the 1932-54 trucks, or find a 1955-59 engine. The only other option would be to switch to center side mounts.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Aug 2009 Posts: 152 'Bolter | | 'Bolter Joined: Aug 2009 Posts: 152 | Thanks for the advice. I will probably go with Dave's suggestion and use a pre 1960 engine.
