| Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,819 | It's possible nothing is wrong. One of the purposes of the oil distributor is to block off oil flow to the head until the connecting rods are getting proper oil flow. Once the engine is actually running instead of pressure being supplied by spinning the pump, you will probably see good oil flow to the head. Jerry
