I think they are the same as the 235.
Alternate/OEM Part Number(s): 1634360010, 25040, 25138, 25148, 740006, 838297
VICTOR REINZ C24529; Alternate/OEM Part Number(s): 838297, 888297
Those gaskets are for the water neck where the lower thermostat housing meets the block. What part numbers I am looking for is where the upper thermostat housing meets the lower thermostat housing/water neck. Thanks though. I was at NAPA and O'Rielys today and they could not come up with anything other than make your own style.
Originally Posted by Uncle Brad
[quote=Tiny_Jaime]The application for the thermostat should be off a '62 C60 with a 261 engine.
"As I lay rubber down the street, I pray for traction I can keep, but if I spin and begin to slide, please dear God protect my sweet ride." -Amen
56 Chevy 3100
