| | | Forums66 Topics128,094 Posts1,056,048 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2012 Posts: 182 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 182 | Need help choosing what thickness of glass setting tape to order. (Not interested in using silicone or urethane.)
The side window gap is about .079 in. Does this indicate 5/64 (.078) or 3/32 (.094) tape?
The windshield gap is .051 on the driver side and .045 on the passenger side (due to slight difference in glass thickness). Does this indicate 3/64 (.047) or 1/16 (.063) tape?
I'm guessing tape slightly thinner than the gap is desirable for ease of assembly, assuming modern glass setting tape is still able to be swelled by oil. Otherwise I would think slightly thicker tape would be required to prevent water intrusion. Which is correct? | | |
