The air is too hot when it comes out of the condenser for the filter/regulator to seperate out the moisture that is created in the compression process. The link Chuckthetruck provided is the best way; I set mine up similarly and it seems to work well, although I don't use it on a daily basis.
The long runs of steel pipe will cool the air enough to seperate the water (steel works better than the rubber line).
