Since the fuel tank was drained, this implies that the truck may have sat unused for some time. There was probably varnish buildup in the fuel lines, which could have moved forward.
If there is a fuel filter in the fuel line right before the carburetor, I would replace it. Once the fuel filter has been replaced, fill the carburetor through the carburetor vent.
And then try to start.
Jon.
