If it were me, I would shy away from a kit. I just did this conversion on my '65 c20, and bought kits for the upgrade, and ended up not using an easy 90% of the kits. The kits either came with very low quality parts, or parts that didn't fit or wouldn't work period. I would recommend sourcing parts from a donor truck from the '73 to 87' range. You'll be much happier. You'll need to re-use your control arms, and have the ball joints pressed in the lowers, and replace the uppers with the bolt-in kind, then it's just swapping things out. It's worth it though. If you have any questions, let me know and I'll answer the best I can.
Shane
Shane's Toys...
2007 Forester XT Limited (2nd Owner)
1991 Cherokee Laredo (2nd Owner)
1981 Chevy 3/4 Ton Fleetside 8,600 Camper Special (3rd Owner)
1965 Chevy 3/4 Ton Fleetside (3rd Owner)
