7 members (Gray_Ghost, dt235sd, Steelonsteel, Nick in Manitou, frogfarmer, Bill Hanlon, mick53),
103
0
Mod | | | Forums66 Topics128,109 Posts1,056,268 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,804 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,804 | Try pushing the truck forward and back in neutral. That will tell you if you've got dragging brakes, or whether there's something causing the driveshaft to bind up going forward. You could also jack up the rear wheels and put the axle housing on jack stands to see if the drivetrain works properly in forward and reverse. If it passes all those checks, you probably have a problem getting the transmission into first gear for some reason. Jerry
Entire Thread
stalling out under load, trouble re-starting
| Woogeroo | 11/30/2015 6:02 AM |
Re: stalling out under load, trouble re-starting
| Uncle Brad | 11/30/2015 6:20 AM |
| Steve_H | 12/02/2015 12:12 AM |
| Uncle Brad | 12/02/2015 1:23 AM |
| Steve_H | 12/02/2015 6:35 PM |
| Uncle Brad | 12/02/2015 7:04 PM |
| Woogeroo | 12/04/2015 6:32 PM |
| Tramp | 12/03/2015 8:50 PM |
| jbennett | 12/05/2015 5:14 PM |
| Larry_58_Burb | 12/06/2015 12:22 PM |
| Woogeroo | 12/06/2015 1:59 PM |
| Hotrod Lincoln | 12/07/2015 4:55 AM |
| Woogeroo | 12/07/2015 8:22 AM |
| Woogeroo | 12/21/2015 12:18 AM | |
