| | | Forums66 Topics128,162 Posts1,056,932 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | Evan, some years back I saw a set up where the bell crank was removed and a small section of angle iron was mounted at that position. The stock rod from the pedal ran through a hole in this plate and the flex cable was connected there as a puller, similar to your instructions. If I remember the stock rod was bent at the tip to attach to the end of cable. Many thanks for the feed back. Now just need to make it work. Jim | | |
