0 members (),
129
3
Mod | | | Forums66 Topics128,110 Posts1,056,241 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,803 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,803 | The only time leaving a bushing in a block during cleaning would be problematic is if the oldtime caustic boil-out tank is used. The "oakite" solution we used 50 years ago would eat diecast seal holders and bronze bushings. Most machine shops quit using caustic hot tank cleaners many years ago due to harassment from the tree huggers.
A regular rotary pressure washer that uses hot water and strong detergent shouldn't hurt a bronze bushing. You should inspect it for wear, however. Jerry
