I've got that setup in my 58 gmc. You are talking about a truck, right? If so you'll need one of the castiron bellhousings from a V8 from trucks from about late 55 thru about mid 70's, one of the starters with 3 bolt pattern and motor mounts. The front V8 mounts didn't work for me so I used the side motor mount cross member from Jim Carter. If you don't have exhaust manifolds use Sanderson Headers from Summit racing Part number SNH-CC3-P. They will give you more room at the steering box. When you get the engine in be sure to check the angle of the drive shaft at the rear of the transmission. You may have to raise the front of the engine. Feel free to PM me for more info. Larry
58 gmc 100 with 350 sbc
