| | | Forums66 Topics128,005 Posts1,055,261 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2015 Posts: 10,997 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 10,997 | Sounds like you're looking for max width outside of tire to outside of tire.
The bed is 50 inches wide (inside). Add 1/8" for the thickness of the two bedsides. Then the fenders are approximately 12" from mounting surface to the lip at the crown of the wheel opening. Just measured the fender I have on my work table. Might be a touch off, but likely within 1/4 inch or so.
From the specifications, the width across rear fenders is 74.5 inches, and the track (center of tread to center of tread on tires) is 61 inches.
