2 members (Cosmo, Wayne67vert),
43
2
Mod | | | Forums66 Topics128,089 Posts1,056,004 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | In studying a distributor, in which I also cutaway the cap, I think I know what your problem is. Distributors have a significant end play in the shaft. When the distributor is installed in the engine the gear rests against the top of the oil pump. This pushes the gear, shaft and rotor up quite a bit. I think that if you push the shaft up, or install the distributor you will find the rotor in line with the cap terminals.
See the USA in your vintage Chevrolet! My Blog | | | |
Entire Thread
1953, 216 distributer issues
| 53 green 1- ton | 11/14/2015 1:05 AM |
Re: 1953, 216 distributer issues
| Denny Graham | 11/14/2015 7:52 AM |
| 53 green 1- ton | 11/14/2015 2:03 PM |
| Denny Graham | 11/14/2015 7:15 PM |
| Hotrod Lincoln | 11/14/2015 8:41 PM |
| 53 green 1- ton | 11/14/2015 10:52 PM |
| Hotrod Lincoln | 11/15/2015 12:21 AM |
| 53 green 1- ton | 11/16/2015 2:22 AM |
| tclederman | 11/16/2015 2:30 AM |
| 53 green 1- ton | 11/16/2015 2:56 AM |
| Pre '68 Dave | 11/16/2015 4:40 AM |
| 53 green 1- ton | 11/16/2015 3:16 PM |
| Pre '68 Dave | 11/16/2015 10:20 PM |
| 53 green 1- ton | 11/16/2015 11:51 PM |
| Pre '68 Dave | 11/17/2015 12:56 AM |
| 53 green 1- ton | 11/17/2015 1:56 AM | |
