2 members (Cosmo, Wayne67vert),
43
2
Mod | | | Forums66 Topics128,089 Posts1,056,004 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | I must have missed that one. What shaft bushing Jim? In the second generation Chevy six distributors that I've seen the shaft runs right in the cast iron housing bore.
The electrons are going to seek a sharp edge or point, that's why the cap appears burnt at the edges of the contacts. Ever notice those Franklin rods atop buildings out on the farm? Theory is that a pointed lightning rod actually ionizes the air around itself, causing the air to become conductive. Having the correct gap between the cap and rotor is calculated and using the correct cap and rotor for the model distributor you have is important.
dg
Denny G Sandwich, IL
Entire Thread
1953, 216 distributer issues
| 53 green 1- ton | 11/14/2015 1:05 AM |
Re: 1953, 216 distributer issues
| Denny Graham | 11/14/2015 7:52 AM |
| 53 green 1- ton | 11/14/2015 2:03 PM |
| Denny Graham | 11/14/2015 7:15 PM |
| Hotrod Lincoln | 11/14/2015 8:41 PM |
| 53 green 1- ton | 11/14/2015 10:52 PM |
| Hotrod Lincoln | 11/15/2015 12:21 AM |
| 53 green 1- ton | 11/16/2015 2:22 AM |
| tclederman | 11/16/2015 2:30 AM |
| 53 green 1- ton | 11/16/2015 2:56 AM |
| Pre '68 Dave | 11/16/2015 4:40 AM |
| 53 green 1- ton | 11/16/2015 3:16 PM |
| Pre '68 Dave | 11/16/2015 10:20 PM |
| 53 green 1- ton | 11/16/2015 11:51 PM |
| Pre '68 Dave | 11/17/2015 12:56 AM |
| 53 green 1- ton | 11/17/2015 1:56 AM | |
