I installed a fiberglass one in a later (1952) truck so there are probably lots of differences. However I will second the advice Paul gives above in his last sentence. I used my wife instead of a decent and patient assistant and ended up trimming too much off. It really needs to be pushed up very firmly if you think you need to trim or better yet make a pattern first as Brad suggests.
