Recently I found my dome light not working. Worked fine before. Thought it was a bad bulb, and replaced it, still not working. Put a test light to it, and one terminal is hot, all the time, regardless of which position the switch is in. Could the headlight switch(which turns on the dome light) be bad?
Thanks
Tramp
dj durant
More pix on Flickr
