| | | Forums66 Topics128,031 Posts1,055,435 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2013 Posts: 1,384 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 1,384 | Cut a couple pieces of pipe (1/2 or 3/4) to fit between the block and the plate and use washers on the bottom between the arms and the block. The mounting bolts have to be tightened up tight to make it safe to use. | | |
