| | | Forums66 Topics128,034 Posts1,055,542 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2003 Posts: 2 Member | | Member Joined: Jan 2003 Posts: 2 | I can weld pretty good with an arc welder. 1/8 to 2 inch material. I know I can weld the unused holes in my frame, grind a little and have a smooth finish. But I need to weld a couple patch panels. Was curious if use of an arc welder would be ok and if so what kind of rod would be best. Or should I find a mig or tig? Ive never used a mig before. Thanks CBK
1936 Chev 1/2 ton locab
