| | | Forums66 Topics128,033 Posts1,055,531 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2003 Posts: 2 Member | | Member Joined: Jan 2003 Posts: 2 | I can weld pretty good with an arc welder. 1/8 to 2 inch material. I know I can weld the unused holes in my frame, grind a little and have a smooth finish. But I need to weld a couple patch panels. Was curious if use of an arc welder would be ok and if so what kind of rod would be best. Or should I find a mig or tig? Ive never used a mig before. Thanks CBK
1936 Chev 1/2 ton locab
| | | | | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | They can be welded with a stick, but you won't be happy with the results. Find a wirefeed with gas and practice, practice, practice.
Fred 52 3600 69 C-10
| | | | | Joined: Jan 2003 Posts: 33 Apprentice | | Apprentice Joined: Jan 2003 Posts: 33 | I have the same question, only what kind of results can you get with a gas welder. I sure it comes out okay, probably have to turn the gas down. Am I right?
Everything you know is wrong.
| | | | | Joined: May 2001 Posts: 46 Member | | Member Joined: May 2001 Posts: 46 | what kind of results can you get with a gas welder. You'll be so impressed you'll kiss your mother-in-law without any second thoughts.  :p | | |
