Hello all,
I have a 51 Chevy 3100 with a 235 in it. Last week I converted it to a HEI ignition from a 78 Nova. It runs great but I have a question about the mechanical advance.
We tested the points distributor in a Sun distributor tester, it had 30 degrees of advance. The HEI only has 20 degrees. From what I read this is correct. But do you just run the engine without the extra timing? Or do you advance the initial 10 degrees from the ball bearing in the flywheel?
Or do you just leave it with 20 degrees?
Some people say I suffer from insanity, in reality, I enjoy every minute of it!
