1 members (klhansen),
158
Mod | | | Forums66 Topics128,089 Posts1,056,141 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2012 Posts: 1,747 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,747 | The seal fits the hub(outside) and the spindle(inside). Stock seal should work fine. Keeping the grease in the hub and bearing. The type of bearing won't matter much unless it is too tall in the hub. Use your finger to feel the bearing sets all the way down to the step. If you can feel a gap, you need to seat it all the way to the seat. Compare the seal outer lip to a stock seal. They should be very close to the same height.
Steve H
